Date/Time: Sat, 11 Jan 2025 07:07:31 +0000
NUMBERS BARS
View Count: 1195
[2016-11-16 18:19:35] |
User834253 - Posts: 5 |
Hi Im using Numbers Bars chart on 5 renko chart with wicks. Im looking at diagonal imbalances %200,%300,%400 on each number bar. Is there any way to calculate all those imbalances ( all positive minus negative ) and plot the number on the chart ? It doesnt have to be %200 300 400 , I could set all imbalances to %300 and calculate those . Please let me know Thanks ! |
[2016-11-16 19:29:07] |
binaryduke - Posts: 373 |
The Numbers Bars calculated values study will let you display Ask Volume minus Bid Volume (i.e. Delta).... or do you just want to calculate from the imbalance values?
[2016-11-16 19:33:16] |
Hey Yes I know I have that study too ( Ask Volume minus Bid Volume -diagonal Delta Sum ) but would like to just calculate those imbalances values or at least one imbalance set to %300 , any way to do that ? Thanks |
[2016-11-16 19:41:08] |
the tools you mentioned its good but when I have a positive delta ratio lets say 2-1 but the sum of %300 and %400 imbalances might be minus 100 contracts ( it takes long time to calculate with calculator ) , now when I have the same situation positive delta 2-1 and positive sum of imbalances the trade has much better probability. Now it all depends on the context but it would be a very useful feature if available. Thanks |
[2016-11-17 03:34:50] |
Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextTypes Specifically you need to use the Ask Bid Vol Difference Diagonal Text Type. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
