Date/Time: Sat, 11 Jan 2025 07:00:42 +0000
time and sales ?
View Count: 1004
[2016-11-16 14:32:32]
zippyzip - Posts: 293
is the time and sales volume study suppose to match time and sales ? very diff output , thanks
[2016-11-16 16:28:50]
Yes, there will be a match assuming Volume Filter settings are disabled on both or are the same.
Date Time Of Last Edit: 2016-11-16 16:29:10
[2016-11-16 16:58:17]
ok i dont see this happening , no filters , this big order didnt come through on the study , so i was wondering if there split up ?
Private File
[2016-11-16 17:25:17]
OK we see what the problem is. Clearly on the Time and Sales window you are using the Combining options which are not supported by the Time and Sales studies.
[2016-11-16 17:37:29]
ah ok ,also trying to plot alert on bar when larger order comes in but its plotting strange , disappearing and reappearing , is there issue doing this ?
[2016-11-16 17:48:34]
From our perspective we do not know exactly what you are doing and seeing so we cannot answer this.
[2016-11-16 17:53:09]
ok so making an alert to plot at anything greater then 6 on time sales vol , it will plot then disappear , so just wondering why or if i had to do something different
Private File
[2016-11-17 03:12:43]
Since the Time and Sales studies use a separate bar for each trade, the persistence of the bar coloring is only going to be until the next trade so it will not be long.
