Date/Time: Sat, 11 Jan 2025 08:21:52 +0000
Unable to connect 2 instances of Sierra Chart to Transact using Sierra Chart data feed
View Count: 574
[2016-11-16 14:01:10]
TapeReader - Posts: 89
I have 2 instances of Sierra Chart running on one machine.
I am able to log into Transact via one instance of Sierra Chart, but I am unable to log into Transact with the second instance of Sierra Chart.
I am using the Sierra Chart data feed.
Both of the instances of Sierra Chart on this one machine are 1481.
I am getting the following in the Message Log:
TransAct Trading | You Are Connecting To A Live Price Server | 2016-11-15 14:57:58 *
TransAct Trading | No Active Accounts | 2016-11-15 14:57:59 *
TransAct Trading | Connection Lost To Transact Price Server. | 2016-11-15 14:57:59 *
I had opened a ticket with Support@transactfutures.com but they pivoted the issue to the Sierra Chart support board.
I am able to run multiple instances of Sierra Chart, and connect to Transact, on alternate machines using the same credentials and configurations.
Any insights here?
[2016-11-16 16:27:37]
This is the relevant message:
You need to ask them why it is that their system is indicating there are no active accounts when connecting with the particular Transact username you are using.
