Date/Time: Sat, 11 Jan 2025 12:01:46 +0000
can not detach a spreadsheet
View Count: 953
[2016-11-16 03:20:14] |
taipeicity - Posts: 52 |
charts can be detached, no problem; but a spreadsheet can NOT be detached |
[2016-11-16 03:37:56] |
We see you are running version 1307. This is not supported in that version. You need to update to the current version. You can do that here: http://www.sierrachart.com/index.php?page=doc/download.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-16 14:51:11] |
after upgrading, spreadsheet detaching works, but a lot of quotes not moving.... all zero
[2016-11-16 16:01:20] |
quotes are not changing on spreadsheet after upgrading to current version
[2016-11-16 16:09:46] |
You need to enable Spreadsheet >> Quote Spreadsheet.
[2016-12-08 06:32:22] |
hi, can i install sierracharts on windows surface pro?
[2016-12-08 06:50:32] |
We had a look at this page: https://www.microsoft.com/surface/en-us/devices/surface-pro-2 Based upon its software and hardware specifications, our reasonable conclusion is that the answer is yes you can use it. Just make sure for permanent storage you get the 256GB size and 8 gigabytes of memory. Do not go less than that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-08 06:51:08
[2016-12-08 06:55:06] |
Actually looks like this one is a more up-to-date one: https://www.microsoft.com/en-us/surface/devices/surface-pro-4/overview Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
