Date/Time: Wed, 15 Jan 2025 12:54:16 +0000
Data On Excel
View Count: 802
[2016-11-15 22:34:34] |
garyw - Posts: 5 |
I need to down load the open,Close, High, low, of the NQ emini to excel is that possible? Gary |
[2016-11-16 03:19:24] |
Yes. You can use the Spreadsheet Study for this: http://www.sierrachart.com/index.php?page=doc/SpreadsheetStudy.html And set the Use Excel Input to Yes: http://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#UseExcel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-28 12:54:56] |
User472520 - Posts: 7 |
Hi I wanted to extract data (NQ Emini) from a spreadsheet study with Alert to a new excel spreadsheet however, the values in the new spreadsheet do not refresh/renew despite them changing on the spreadsheet study with Alert excel file. Any suggestions on how to make them both match? Regards |
[2017-06-28 19:03:55] |
It is not clear exactly what you are doing. How are you doing this: I wanted to extract data (NQ Emini) from a spreadsheet study with Alert to a new excel spreadsheet
