Date/Time: Sat, 25 Jan 2025 21:02:10 +0000
Sound
View Count: 614
[2016-11-15 10:49:48] |
User39772 - Posts: 311 |
Is it possible to play a sount if a stop is hit, an order is dilled or a target is reached, e.g. an appropriate voice sound ?
[2016-11-15 16:58:57] |
Yes. There are various alerts that can be set for different trading events. Refer to these settings here: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#GeneralTradeSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
