Date/Time: Sun, 20 Sep 2026 18:00:32 +0000
The HMS_TIME function
View Count: 1802
[2016-11-15 05:05:33]
enemyspy - Posts: 307
Hi I am trying to convert 15 minutes into and integer using the method outlined here: http://www.sierrachart.com/index.php?page=doc/SCDateTime.html#TIME_TO_HMS. The purpose is to iterativly initialize The Key values of an STL map container at 15 minute time increments as shown below . It seems to increment the time by approximately 12 minutes instead of the 15. Is the HMS Time Function being used properly in this example?
To initialize the container I do this:
int Time = HMS_TIME(6,30,0);
int TimeInc = HMS_TIME(0,15,0);
int TimeEnd = HMS_TIME(13,15,0);
std::map<int,std::map<float,int>> DistributionAtTime;
std::map<float,int> Temp;
for(int i = Time;Time<=TimeEnd; i+=TimeInc) DistributionAtTime[i] = Temp;
[2016-11-15 06:54:09]
All that we can say is this is 15 minutes in seconds
HMS_TIME(0,15,0);
