Date/Time: Tue, 06 Oct 2026 02:54:58 +0000
Using DMI in the CrossOver function
View Count: 1628
[2016-11-15 02:07:07]
AcquaLife - Posts: 33
I am trying to compare the negative DMI and positive DMI for a crossover. However, the crossover function takes arrays while the data in the DMI are not arrays. I tried several ways of putting the value of the pos DMI and neg DMI in two different arrays and then using the crossover function with no luck. I also followed the code example:
This is an example of looking for a crossover between the values in
// a subgraph and a fixed value. We first have to put the fixed value
// into an array. We are using one of the Subgraph internal arrays.
sc.Subgraph[2].Arrays[8][sc.Index] = 100.0;
if (sc.CrossOver(sc.Subgraph[2], sc.Subgraph[2].Arrays[8]) == CROSS_FROM_BOTTOM)
//Code
I though i could do what you did with the sc.Subgraph[2].Arrays[8][sc.Index] = 100.00 and replace the 100 with pos DMI and another line of code with neg DMI in array 9. Also, when i used the crossover function instead of putting both DMI pos and DMI neg as arguments, I just put one in with another known array. No matter what i do i keep getting this error: 'int s_sc::CrossOver(SCFloatArrayRef,SCFloatArrayRef,int)': cannot convert argument 1 from 'float' to 'SCFloatArrayRef'
This is the piece of code i am working with:
sc.DMI(sc.BaseDataIn, sc.Subgraph[1], 10);
  float DMIPos = sc.Subgraph[1][sc.Index];
  float DMINeg = sc.Subgraph[1].Arrays[0][sc.Index];
  sc.Subgraph[1].Arrays[1][sc.Index]=DMIPos;
  sc.Subgraph[1].Arrays[2][sc.Index]=DMINeg;
[2016-11-15 03:54:48]
SCSubgraphRef DIPlus = sc.Subgraph[0];
SCSubgraphRef DIMinus = sc.Subgraph[1];
sc.DMI(sc.BaseData, DIPlus, DIMinus, Length.GetInt());
if (sc.CrossOver(DIPlus.Data, DIMinus.Data) == CROSS_FROM_BOTTOM)
//Code
Date Time Of Last Edit: 2016-11-15 03:55:17
