Date/Time: Sat, 11 Jan 2025 06:51:44 +0000
ZNZ6 on Demo
View Count: 859
[2016-11-14 23:52:56] |
User104854 - Posts: 456 |
Hi. I can't seem to get this symbol to update on the demo. It works fine on the live account. It works fine on another platform so it's not the data feed. I have one chartbook open with 6 charts. All of the other 5 charts are updating. According to Gain I can have up to 10 charts so this shouldn't be an issue. Can you check this out please? |
[2016-11-15 01:38:29] |
Provide a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-15 02:44:45] |
The log is below. I have 6 charts up on the demo. When the ZNZ6 loads up it will say 'Symbol is unknown' but will still load the historical data. Once the chart is up it is not updating. I was having the same trouble with the NQZ6 but it seems to be working now. The others are ES, GGC, GCL, and ZBZ6 and they are all working just fine. I also updated to the latest version and restarted my computer. Thanks for your help. Reading Internal Order ID file. | 2016-11-14 18:31:04 Reading Trade Orders file. | 2016-11-14 18:31:04 Reading Trade Positions file. | 2016-11-14 18:31:04 Software version: 1481 | 2016-11-14 18:31:04 Uses New Spreadsheets | 2016-11-14 18:31:04 Usage end date: 2016-12-10 | 2016-11-14 18:31:04 Enabled for: Advanced Features. | 2016-11-14 18:31:04 Enabled for: Advanced Features 2. | 2016-11-14 18:31:04 Enabled for: Sierra Chart Historical Data Service. | 2016-11-14 18:31:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-11-14 18:31:04 Current selected Data/Trading service: GAIN Capital/OEC | 2016-11-14 18:31:04 Chart Update Interval: 500 | 2016-11-14 18:31:04 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-11-14 18:31:04 2016-11-14 18:31:12 Local computer time | 2016-11-14 18:31:04 2016-11-15 02:31:12 Local computer time in UTC | 2016-11-14 18:31:04 2016-11-14 18:31:12 Local computer time in SC Time Zone | 2016-11-14 18:31:04 2016-11-15 02:31:22 Server time in UTC | 2016-11-14 18:31:04 Local computer UTC time and Server UTC time difference: 13 seconds. | 2016-11-14 18:31:04 Program path: C:\SierraChart\ | 2016-11-14 18:31:04 Data Files path: C:\SierraChart\Data\ | 2016-11-14 18:31:04 OS Version Number: 6.2 | 2016-11-14 18:31:04 Locale Setting: C | 2016-11-14 18:31:04 Created the DTC Protocol server. | 2016-11-14 18:31:04 DTC Protocol Server listening on port 11099. | 2016-11-14 18:31:04 Created the DTC Protocol historical data server. | 2016-11-14 18:31:04 HD Server Manager | Listening on port 11098 | 2016-11-14 18:31:04 Checking for new symbol settings for oec | 2016-11-14 18:31:04 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-14 18:31:04 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-11-14 18:31:04 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-11-14 18:31:04 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-11-14 18:31:14 Symbol settings are up-to-date for oec | 2016-11-14 18:31:15 GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2016-11-14 18:31:18 GAIN Capital FIX Trading socket (0) | Resolved address sim.gainfutures.com to IP 64.94.37.207. | 2016-11-14 18:31:18 GAIN Capital FIX Trading socket (4) | Connected. | 2016-11-14 18:31:18 GAIN Capital FIX Trading: Sending the Logon message. | 2016-11-14 18:31:18 GAIN Capital FIX Trading | Connected to trading server. | 2016-11-14 18:31:18 GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2016-11-14 18:31:18 GAIN Capital FAST Data socket (0) | Resolved address sim.gainfutures.com to IP 64.94.37.207. | 2016-11-14 18:31:18 GAIN Capital FAST Data socket (5) | Connected. | 2016-11-14 18:31:18 GAIN Capital FAST Data: Sending the Hello message. | 2016-11-14 18:31:18 GAIN Capital FAST Data: Sending the Logon message. | 2016-11-14 18:31:18 GAIN Capital/OEC | Connected to data and trading server. | 2016-11-14 18:31:18 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-11-14 18:31:20 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-11-14 18:31:20 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-11-14 18:31:20 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-11-14 18:31:20 GAIN Capital/OEC | Received collateral inquiry acknowledgment. Result = 3. | 2016-11-14 18:31:23 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 3. Request Status: 2 | 2016-11-14 18:31:24 ESZ6 [CV] 30 Min #1 | Reloading chart. | 2016-11-14 18:31:38 ZBZ6 [CV] 30 Min #2 | Reloading chart. | 2016-11-14 18:31:38 Unable to determine transition date based on volume from files: ZBU16.dly, ZBZ16.dly | 2016-11-14 18:31:38 The ZBZ16.dly symbol may not be the active contract month. | 2016-11-14 18:31:38 NQZ6 [CV] 30 Min #4 | Reloading chart. | 2016-11-14 18:31:38 GGCZ6 [CV] 30 Min #5 | Reloading chart. | 2016-11-14 18:31:38 GCLZ6 [CV] 30 Min #6 | Reloading chart. | 2016-11-14 18:31:38 ZNZ6 [CV] 30 Min #3 | Reloading chart. | 2016-11-14 18:31:38 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-11-14 18:31:58 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-11-14 18:31:58 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-11-14 18:31:58 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-11-14 18:31:58 Delaying start of download for ESZ6 | 2016-11-14 18:31:58 GAIN Capital/OEC | Starting real-time market data updates for: ZBZ6. ID: 2 | 2016-11-14 18:31:58 GAIN Capital/OEC | Requesting security definition data for: ZBZ6. ID: 2 | 2016-11-14 18:31:58 Intraday data recording state for symbol ZBZ6 is set to download 'Pending'. | 2016-11-14 18:31:58 Delaying start of download for ESZ6 | 2016-11-14 18:31:58 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 3 | 2016-11-14 18:31:58 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 3 | 2016-11-14 18:31:58 Intraday data recording state for symbol NQZ6 is set to download 'Pending'. | 2016-11-14 18:31:58 HD Request # 2 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-11-14 18:31:58 HD Request # 2 | Download start date-time: 2016-11-14 18:16:39.000 | 2016-11-14 18:31:58 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-11-14 18:31:58 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-11-14 18:31:58 Socket (6) | Connected. | 2016-11-14 18:31:58 HD Request # 2 | Setting DTC encoding to Binary VLS | 2016-11-14 18:31:58 HD Request # 2 | Sending historical data logon request message. | 2016-11-14 18:31:58 HD Request # 2 | Requesting Intraday data. Start date-time: 2016-11-14 18:16:39. Record interval: 0. Symbol: ESZ6 | 2016-11-14 18:31:58 HD Request # 2 | Decompressing data. | 2016-11-14 18:31:58 HD Request # 2 | Receiving Intraday data for ESZ6 starting at 2016-11-14 18:16:39 | 2016-11-14 18:31:58 HD Request # 2 | Timestamp of first Intraday data file record written: 2016-11-14 18:17:00 | 2016-11-14 18:31:58 Socket (6) | Shutdown and closed. | 2016-11-14 18:31:58 The network socket for historical data has been closed. | 2016-11-14 18:31:58 GAIN Capital/OEC | Starting real-time market data updates for: GGCZ6. ID: 4 | 2016-11-14 18:31:58 GAIN Capital/OEC | Requesting security definition data for: GGCZ6. ID: 4 | 2016-11-14 18:31:58 Intraday data recording state for symbol GGCZ6 is set to download 'Pending'. | 2016-11-14 18:31:58 HD Request # 2 | Received 701 records from 2016-11-14 18:16:39 to 2016-11-14 18:32:21 (15.7 minutes) and wrote 699 records for ESZ6 | 2016-11-14 18:31:58 Added 19 Time and Sales records to Intraday data file for ESZ6 after download. | 2016-11-14 18:31:58 HD Request # 2 | Intraday download COMPLETE for ESZ6. Completion time: 14s. Unique request ID: 1 | 2016-11-14 18:31:58 Removed historical data download ID 1 | 2016-11-14 18:31:58 Real-time Intraday chart data file updates started for ESZ6 | 2016-11-14 18:31:58 Intraday chart data file opened for ESZ6 | 2016-11-14 18:31:58 Delaying start of download for ZBZ6 | 2016-11-14 18:31:58 GAIN Capital/OEC | Starting real-time market data updates for: GCLZ6. ID: 5 | 2016-11-14 18:31:58 GAIN Capital/OEC | Requesting security definition data for: GCLZ6. ID: 5 | 2016-11-14 18:31:58 Intraday data recording state for symbol GCLZ6 is set to download 'Pending'. | 2016-11-14 18:31:58 HD Request # 3 | Downloading Intraday chart data for ZBZ6 to the file ZBZ6.scid. Service: oec | 2016-11-14 18:31:58 HD Request # 3 | Download start date-time: 2016-11-14 18:16:39.000 | 2016-11-14 18:31:58 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2016-11-14 18:31:58 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-11-14 18:31:58 Socket (7) | Connected. | 2016-11-14 18:31:58 HD Request # 3 | Setting DTC encoding to Binary VLS | 2016-11-14 18:31:58 HD Request # 3 | Sending historical data logon request message. | 2016-11-14 18:31:58 GAIN Capital/OEC | Starting real-time market data updates for: ZNZ6. ID: 6 | 2016-11-14 18:31:58 GAIN Capital/OEC | Requesting security definition data for: ZNZ6. ID: 6 | 2016-11-14 18:31:58 Intraday data recording state for symbol ZNZ6 is set to download 'Pending'. | 2016-11-14 18:31:58 HD Request # 3 | Requesting Intraday data. Start date-time: 2016-11-14 18:16:39. Record interval: 0. Symbol: ZBZ6 | 2016-11-14 18:31:58 HD Request # 3 | Decompressing data. | 2016-11-14 18:31:58 HD Request # 3 | Receiving Intraday data for ZBZ6 starting at 2016-11-14 18:16:39 | 2016-11-14 18:31:58 Symbol Error - ZNZ6 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-11-14 18:31:58 HD Request # 3 | Timestamp of first Intraday data file record written: 2016-11-14 18:17:25 | 2016-11-14 18:32:28 Socket (7) | Shutdown and closed. | 2016-11-14 18:32:28 The network socket for historical data has been closed. | 2016-11-14 18:32:28 HD Request # 3 | Received 380 records from 2016-11-14 18:16:39 to 2016-11-14 18:32:10 (15.5 minutes) and wrote 379 records for ZBZ6 | 2016-11-14 18:32:28 HD Request # 3 | Intraday download COMPLETE for ZBZ6. Completion time: 3s. Unique request ID: 2 | 2016-11-14 18:32:28 Removed historical data download ID 2 | 2016-11-14 18:32:28 Real-time Intraday chart data file updates started for ZBZ6 | 2016-11-14 18:32:28 Intraday chart data file opened for ZBZ6 | 2016-11-14 18:32:28 HD Request # 4 | Downloading Intraday chart data for NQZ6 to the file NQZ6.scid. Service: oec | 2016-11-14 18:32:28 HD Request # 4 | Download start date-time: 2016-11-14 18:16:41.000 | 2016-11-14 18:32:28 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2016-11-14 18:32:28 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-11-14 18:32:28 Socket (8) | Connected. | 2016-11-14 18:32:28 HD Request # 4 | Setting DTC encoding to Binary VLS | 2016-11-14 18:32:28 HD Request # 4 | Sending historical data logon request message. | 2016-11-14 18:32:28 HD Request # 4 | Requesting Intraday data. Start date-time: 2016-11-14 18:16:41. Record interval: 0. Symbol: NQZ6 | 2016-11-14 18:32:28 HD Request # 4 | Decompressing data. | 2016-11-14 18:32:28 HD Request # 4 | Receiving Intraday data for NQZ6 starting at 2016-11-14 18:16:41 | 2016-11-14 18:32:28 HD Request # 4 | Timestamp of first Intraday data file record written: 2016-11-14 18:17:00 | 2016-11-14 18:32:28 Socket (8) | Shutdown and closed. | 2016-11-14 18:32:28 The network socket for historical data has been closed. | 2016-11-14 18:32:28 HD Request # 4 | Received 206 records from 2016-11-14 18:16:41 to 2016-11-14 18:32:40 (16.0 minutes) and wrote 201 records for NQZ6 | 2016-11-14 18:32:28 HD Request # 4 | Intraday download COMPLETE for NQZ6. Completion time: 2s. Unique request ID: 3 | 2016-11-14 18:32:28 Removed historical data download ID 3 | 2016-11-14 18:32:28 Real-time Intraday chart data file updates started for NQZ6 | 2016-11-14 18:32:28 Intraday chart data file opened for NQZ6 | 2016-11-14 18:32:28 HD Request # 5 | Downloading Intraday chart data for GGCZ6 to the file GGCZ6.scid. Service: oec | 2016-11-14 18:32:28 HD Request # 5 | Download start date-time: 2016-11-14 18:16:56.000 | 2016-11-14 18:32:28 HD Request # 5 | Using server: ds3.sierracharts.com port 10149 | 2016-11-14 18:32:28 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-11-14 18:32:28 Socket (9) | Connected. | 2016-11-14 18:32:28 HD Request # 5 | Setting DTC encoding to Binary VLS | 2016-11-14 18:32:28 HD Request # 5 | Sending historical data logon request message. | 2016-11-14 18:32:28 HD Request # 5 | Requesting Intraday data. Start date-time: 2016-11-14 18:16:56. Record interval: 0. Symbol: GGCZ6 | 2016-11-14 18:32:28 HD Request # 5 | Decompressing data. | 2016-11-14 18:32:28 HD Request # 5 | Receiving Intraday data for GGCZ6 starting at 2016-11-14 18:16:56 | 2016-11-14 18:32:28 HD Request # 5 | Timestamp of first Intraday data file record written: 2016-11-14 18:16:59 | 2016-11-14 18:32:28 Socket (9) | Shutdown and closed. | 2016-11-14 18:32:28 The network socket for historical data has been closed. | 2016-11-14 18:32:28 HD Request # 5 | Received 763 records from 2016-11-14 18:16:56 to 2016-11-14 18:32:28 (15.5 minutes) and wrote 761 records for GGCZ6 | 2016-11-14 18:32:28 HD Request # 5 | Intraday download COMPLETE for GGCZ6. Completion time: 2s. Unique request ID: 4 | 2016-11-14 18:32:28 Removed historical data download ID 4 | 2016-11-14 18:32:28 Real-time Intraday chart data file updates started for GGCZ6 | 2016-11-14 18:32:28 Intraday chart data file opened for GGCZ6 | 2016-11-14 18:32:28 HD Request # 6 | Downloading Intraday chart data for GCLZ6 to the file GCLZ6.scid. Service: oec | 2016-11-14 18:32:28 HD Request # 6 | Download start date-time: 2016-11-14 18:16:58.000 | 2016-11-14 18:32:28 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2016-11-14 18:32:28 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-11-14 18:32:33 Socket (10) | Connected. | 2016-11-14 18:32:33 HD Request # 6 | Setting DTC encoding to Binary VLS | 2016-11-14 18:32:33 HD Request # 6 | Sending historical data logon request message. | 2016-11-14 18:32:33 HD Request # 6 | Requesting Intraday data. Start date-time: 2016-11-14 18:16:58. Record interval: 0. Symbol: GCLZ6 | 2016-11-14 18:32:34 HD Request # 6 | Decompressing data. | 2016-11-14 18:32:34 HD Request # 6 | Receiving Intraday data for GCLZ6 starting at 2016-11-14 18:16:58 | 2016-11-14 18:32:34 HD Request # 6 | Timestamp of first Intraday data file record written: 2016-11-14 18:17:05 | 2016-11-14 18:32:34 Socket (10) | Shutdown and closed. | 2016-11-14 18:32:34 The network socket for historical data has been closed. | 2016-11-14 18:32:34 HD Request # 6 | Received 952 records from 2016-11-14 18:16:58 to 2016-11-14 18:32:38 (15.7 minutes) and wrote 950 records for GCLZ6 | 2016-11-14 18:32:34 HD Request # 6 | Intraday download COMPLETE for GCLZ6. Completion time: 1s. Unique request ID: 5 | 2016-11-14 18:32:34 Removed historical data download ID 5 | 2016-11-14 18:32:34 Real-time Intraday chart data file updates started for GCLZ6 | 2016-11-14 18:32:34 Intraday chart data file opened for GCLZ6 | 2016-11-14 18:32:34 HD Request # 7 | Downloading Intraday chart data for ZNZ6 to the file ZNZ6.scid. Service: oec | 2016-11-14 18:32:34 HD Request # 7 | Download start date-time: 2016-11-14 18:12:11.000 | 2016-11-14 18:32:34 HD Request # 7 | Using server: ds3.sierracharts.com port 10149 | 2016-11-14 18:32:34 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-11-14 18:32:34 Socket (11) | Connected. | 2016-11-14 18:32:34 HD Request # 7 | Setting DTC encoding to Binary VLS | 2016-11-14 18:32:34 HD Request # 7 | Sending historical data logon request message. | 2016-11-14 18:32:34 HD Request # 7 | Requesting Intraday data. Start date-time: 2016-11-14 18:12:11. Record interval: 0. Symbol: ZNZ6 | 2016-11-14 18:32:34 HD Request # 7 | Decompressing data. | 2016-11-14 18:32:34 HD Request # 7 | Receiving Intraday data for ZNZ6 starting at 2016-11-14 18:12:11 | 2016-11-14 18:32:34 HD Request # 7 | Timestamp of first Intraday data file record written: 2016-11-14 18:12:21 | 2016-11-14 18:32:34 Socket (11) | Shutdown and closed. | 2016-11-14 18:32:34 The network socket for historical data has been closed. | 2016-11-14 18:32:34 HD Request # 7 | Received 1276 records from 2016-11-14 18:12:11 to 2016-11-14 18:32:12 (20.0 minutes) and wrote 1275 records for ZNZ6 | 2016-11-14 18:32:34 HD Request # 7 | Intraday download COMPLETE for ZNZ6. Completion time: 0s. Unique request ID: 6 | 2016-11-14 18:32:34 Removed historical data download ID 6 | 2016-11-14 18:32:34 Real-time Intraday chart data file updates started for ZNZ6 | 2016-11-14 18:32:34 Intraday chart data file opened for ZNZ6 | 2016-11-14 18:32:34 Opened cached Intraday file: C:\SierraChart\Data\ESZ6.scid | 2016-11-14 18:32:41 Opened cached Intraday file: C:\SierraChart\Data\ZBZ6.scid | 2016-11-14 18:32:41 Opened cached Intraday file: C:\SierraChart\Data\NQZ6.scid | 2016-11-14 18:32:41 Opened cached Intraday file: C:\SierraChart\Data\GGCZ6.scid | 2016-11-14 18:32:41 Opened cached Intraday file: C:\SierraChart\Data\GCLZ6.scid | 2016-11-14 18:32:41 Intraday data recording state for symbol ZNZ6 is set to download 'Pending'. | 2016-11-14 18:35:35 HD Request # 8 | Downloading Intraday chart data for ZNZ6 to the file ZNZ6.scid. Service: oec | 2016-11-14 18:35:35 HD Request # 8 | Download start date-time: 2016-11-13 23:29:59.000 | 2016-11-14 18:35:35 HD Request # 8 | Disabling Intraday chart updating for symbol during historical data download. | 2016-11-14 18:35:35 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2016-11-14 18:35:35 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-11-14 18:35:35 Socket (14) | Connected. | 2016-11-14 18:35:35 HD Request # 8 | Setting DTC encoding to Binary VLS | 2016-11-14 18:35:35 HD Request # 8 | Sending historical data logon request message. | 2016-11-14 18:35:35 HD Request # 8 | Requesting Intraday data. Start date-time: 2016-11-13 23:29:59. Record interval: 0. Symbol: ZNZ6 | 2016-11-14 18:35:36 HD Request # 8 | Decompressing data. | 2016-11-14 18:35:36 HD Request # 8 | Receiving Intraday data for ZNZ6 starting at 2016-11-13 23:29:59 | 2016-11-14 18:35:36 HD Request # 8 | Truncating file to starting date-time of 2016-11-13 23:29:59 | 2016-11-14 18:35:36 HD Request # 8 | Timestamp of first Intraday data file record written: 2016-11-13 23:29:59 | 2016-11-14 18:35:36 Socket (14) | Shutdown and closed. | 2016-11-14 18:35:37 The network socket for historical data has been closed. | 2016-11-14 18:35:37 HD Request # 8 | Received 321512 records from 2016-11-13 23:29:59 to 2016-11-14 18:35:34 (19.1 hours) and wrote 321512 records for ZNZ6 | 2016-11-14 18:35:37 HD Request # 8 | Intraday download COMPLETE for ZNZ6. Completion time: 0s. Unique request ID: 7 | 2016-11-14 18:35:37 Removed historical data download ID 7 | 2016-11-14 18:35:37 Real-time Intraday chart data file updates started for ZNZ6 | 2016-11-14 18:35:37 Intraday chart data file opened for ZNZ6 | 2016-11-14 18:35:37 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2016-11-14 18:35:37 HD Request # 8 | Reloading Intraday charts for ZNZ6 | 2016-11-14 18:35:37 Reloading all charts with filename: ZNZ6.scid | 2016-11-14 18:35:37 ZNZ6 [CV] 30 Min #3 | Reloading chart. | 2016-11-14 18:35:37 Requesting market depth updates for: NQZ6 if supported. | 2016-11-14 18:36:59 Unsubscribed from market depth data for NQZ6 | 2016-11-14 18:37:44 NQZ6 [CV] 30 Min #7 | Reloading chart. | 2016-11-14 18:37:50 ZNZ6 [CV] 30 Min #7 | Reloading chart. | 2016-11-14 18:38:12 |
[2016-11-15 03:12:06] |
This is the relevant message: Symbol Error - ZNZ6 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-11-14 18:31:58 So you need to contact Gain Capital to have them increase the limit. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-15 03:14:13] |
Ok. Thank you for your help.
