Date/Time: Sat, 11 Jan 2025 06:50:59 +0000
sierra charts not funtioning
View Count: 678
[2016-11-14 17:03:22] |
User680112 - Posts: 1 |
There seems to be a problem with the sierra charts software. I am not getting the same candle bars the same as the rest of the group. The http://www.sierrachart.com/image.php?Image=1479142916860.png indicators are also not the same. |
[2016-11-14 17:19:11] |
We need to know specifically what the difference is compared to another chart. There is nothing we can tell from the chart image you gave. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
