Date/Time: Sat, 11 Jan 2025 06:54:17 +0000
ACSIL setting the stop loss in ticks
View Count: 832
[2016-11-14 07:28:23] |
User514837 - Posts: 47 |
Good morning, following the trading examples in the ACS_Source folder I have been able to make my first simple example system, which after backtesting seems to be working as I want it to. I have one question about the stop loss however: It has been set like this: StopValue.SetFloat(1.0f); I'm not sure what this 1.0 represents. FUrthermore, looking into the order documentation page I couldn't find anything related to it. What does this represent? And how could I set my stop in ticks, say I wanted the stop loss to be 50 ticks away from the entry. Thank you for your help. |
[2016-11-14 18:45:41] |
This is explained in detail in this section here: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#StopOffset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
