Date/Time: Sat, 11 Jan 2025 07:03:45 +0000
Visualization of trades on charts
View Count: 693
[2016-11-13 09:09:15] |
Orion - Posts: 12 |
Hi SC Support and users, Are there any ACSIL scripts/code for displaying trades (be that simulated or real) on charts by using lines and arrows - something like the attached picture? I would like to incorporate that in my ACSIL trading systems to visualize the trades real-time. Have searched the discussion board but couldn't find an answer. Sorry if I have overlooked anything. Thanks in advance! Regards, Orion |
trades.png / V - Attached On 2016-11-13 09:05:12 UTC - Size: 5.46 KB - 222 views |
[2016-11-13 10:17:56] |
Refer to this section here: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-13 13:16:08] |
Orion - Posts: 12 |
Hi SC Support, It works. Sorry for overlooking that. Thank you. |
