Date/Time: Sat, 11 Jan 2025 06:52:41 +0000
How to expand more info from the "Export Bar and Study Data to Text File"?
View Count: 637
[2016-11-11 20:44:39]
User129630 - Posts: 22
There's this "Export Bar and Study Data to Text File" function under the [Edit] menu.
Currently, it only export a portion (not all) of the sc.BaseDataIn[][] info such as SC_HIGH and SC_LOW, but SC_UPVOL or SC_DOWNVOL are not included. Is there anyway to export more info from this? Specifically, I am interested in all the info as documented in the sc.BaseDataIn[][]: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scBaseDataIn.
[2016-11-11 20:47:37]
No. This is not supported.
[2016-11-11 20:56:12]
So, I will have to develop an ACSIL study to dump the info out.
Any chance of making this as a feature request for improvement to the future software release?
[2016-11-11 21:51:27]
Refer to:
Notice: Suggestions (Currently not accepting)
[2016-11-12 05:22:13]
What you can do is create a custom study that outputs to study Subgraphs all of the additional Base Data arrays.
And then follow the instructions here to export that data:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetAdditionalInfo.html#ExportingSheetDataToTextFile
