Date/Time: Sat, 11 Jan 2025 07:00:42 +0000
Trade Activity Log Columns
View Count: 658
[2016-11-11 19:14:28] |
User104854 - Posts: 456 |
Hi. I'm looking at the Trade Activity Log and specifically, the Trade tab. I want to have the most recent trades at the top. Is there a way to do this?
[2016-11-11 19:27:40] |
No. This is not supported.
[2016-11-11 19:39:52] |
Is this something you can add? Seems like it'd be pretty simple. The Orders tab on Orders and Positions already allows this.
[2016-11-11 19:48:36] |
We will consider it later on. It is not something we can get to any time soon.
