Date/Time: Sat, 11 Jan 2025 07:00:18 +0000
Scale
View Count: 608
[2016-11-11 18:19:00] |
toews&kane - Posts: 209 |
Hi there, Is there a way to always keep the highest and lowest bar in view to stretch to the upper and lower bounds of the region? Cheers |
[2016-11-11 18:42:31] |
Yes. This is the default. Make sure the Scale Range is set to Automatic: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Also reset the scale with Chart >> Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-11 18:46:27] |
My scales are always set at automatic. But I find that as the day moves along time pasts the top and bottoms are more squished needing me to vertical adjust it so the highs and lows of the current window are stretched to make take advantage of the whole vertical chart region. Any ideas on how I would not have to do that? |
[2016-11-11 18:47:27] |
Maybe it's the last price always centered setting? How do I set the scale to automatic but not have to fix the last price in the middle? I just find it sometimes only using half of the chart region when there's still so much room top or bottom. Cheers |
[2016-11-11 19:01:01] |
You just need to set the Scale Range to Automatic and do not change that. When you notice the problem, select Chart >> Reset Scales and provide an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
