Date/Time: Sat, 11 Jan 2025 06:46:16 +0000
adjusting orders from chart
View Count: 846
[2016-11-11 15:28:38] |
User170575 - Posts: 221 |
Hi--I cant seem to adjust my OCO orders by dragging the order on the chart...your thoughts appreciated. Many thanks, CJ |
[2016-11-11 17:41:23] |
Refer to: Chart Trading and the Chart DOM: Modifying and Canceling Orders on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-11 18:45:54] |
Once again seems to be an TDAmeritrade issue I think--here is the log---any suggestions--besides moving my acct to IB?---Thanks again Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: xxxx. Service Order ID: (none). Symbol: NUGT | 2016-11-11 13:29:59 * Order Error - TDA order update. Your order(s) can't be placed. The total quantity of outstanding open sell order(s) exceeds the quantity you hold. Internal Order ID: xxxx. Service Order ID: (none). Symbol: NUGT | 2016-11-11 13:30:07 * Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: xxxx. Service Order ID: (none). Symbol: NUGT | 2016-11-11 13:30:14 * Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: xxxx. Service Order ID: (none). Symbol: NUGT | 2016-11-11 13:30:15 * Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: xxxx. Service Order ID: (none). Symbol: NUGT | 2016-11-11 13:30:15 * Order Error - TDA order update. Your order(s) can't be placed. The total quantity of outstanding open sell order(s) exceeds the quantity you hold. Internal Order ID: xxxx. Service Order ID: (none). Symbol: NUGT | 2016-11-11 13:30:29 * Requesting order status for non-responsive order. | Symbol: NUGT | TradeAccount: xxxxx | InternalOrderID: xxxx | 2016-11-11 13:30:44 * |
[2016-11-11 19:00:29] |
There is no reason to be suppressing the order IDs. There is nothing private about that information at all. And it makes it harder for us to understand the information. You need to ask TD Ameritrade about this: Your order(s) can't be placed. The total quantity of outstanding open sell order(s) exceeds the quantity you hold
