Date/Time: Sat, 11 Jan 2025 06:54:38 +0000
limit orders appear bunched up on DOM - regardless of scale
View Count: 694
[2016-11-11 13:21:10] |
User60518 - Posts: 106 |
this is only applicable to the 6E contract - all others appear fine. http://www.sierrachart.com/image.php?Image=1478870420471.png chartbook attached None of my other DOM's appear this way - was fine on rithmic and Cuningham feeds - this is transact Cheers Date Time Of Last Edit: 2016-11-11 13:24:08
Chartbook2.cht - Attached On 2016-11-11 13:23:48 UTC - Size: 29.67 KB - 323 views |
[2016-11-11 17:13:26] |
Select Chart >> Chart Settings and make sure the Tick Size is set to .00005. After changing that, Auto Scale the Chart DOM: The Chart DOM Scale: Auto Scale the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
