Date/Time: Sat, 11 Jan 2025 06:58:14 +0000
How to lock the number of contracts in DOM
View Count: 776
[2016-11-11 12:11:58] |
Alexander - Posts: 15 |
Trying to change the time frame by keyboard, somebody can unintentionally change the number of contracts in the "quantity" field (if the cursor is accidentally located in this field). Thank you in advance
[2016-11-11 16:43:05] |
This is not supported.
