Date/Time: Sat, 11 Jan 2025 07:08:20 +0000
Chart DOM Last Price Text Color Does Not Work
View Count: 898
[2016-11-11 02:03:14] |
Acro - Posts: 441 |
Hi, I am trying to better track current price in my Chart DOM but one thing that keeps frustrating me is that the Graphic Setting (whether global or local) for Chart DOM Last Price Text At Ask, Last Price Text At Bid or Bold DOM Last Price does not work for any Chart DOM. I have tried and tried to enable these settings but they only seem to work for Trade DOMs and not Chart DOMs. Is there something I am missing ? Thanks |
[2016-11-11 05:13:40] |
Make sure you enable the "Enable" option for these color settings: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Last Price Text Bid Trade We did verify that these color settings do work with the Chart DOM. Not sure about Bold DOM Last Price. We would have to look into that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-11 06:54:43] |
Acro - Posts: 441 |
Thank You. I went and tested every feature of my chart that had this issue and found the problem. If I set Graph Draw Type in chart settings to "Blank" I lose the graphic settings in the Chart DOM for last price. I will have to find a workaround as I have a third party footprint indicator so I like to keep the chart bars blank |
[2016-11-11 08:05:38] |
In the latest prerelease, we solved the problem of the last trade price box not showing when using a Graph Draw Type of Blank. So if you update that will solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-11 08:34:09] |
Acro - Posts: 441 |
Thanks, Yes all of these are now fixed in the very latest prerelease Date Time Of Last Edit: 2016-11-11 12:54:14
