Date/Time: Sat, 11 Jan 2025 06:53:01 +0000
DOM Price Column
View Count: 814
[2016-11-10 22:10:37]
sigmadict - Posts: 95
I want to know if it is possible to move the Price Column in the DOM window (The Dom is Detached from the Chart).
In the standard DOM the Price Column is at the right, and the orders appear at the left.
I would like that the orders appear at the right and the the Price Column appears at the left.
If it's not possible, let me know if you think that could be done.
Regards
[2016-11-10 22:22:24]
Yes. Refer to:
Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns
[2016-11-11 00:36:05]
Thanks for the reply.
I read your reference but I did not find out what I am looking for, so I made a drawing to try to show you and explain you better.
What I want to do is pass the Orders boxes (with the Position Lines) on the other side of all the Columns, at the full right of the Trade DOM Window.
The blue arrow on the drawing shows where I would like the items to be.
I put the link here to the Sierra Screenshot :
http://www.sierrachart.com/image.php?Image=147882393926.png
Regards
[2016-11-11 01:00:03]
It is not possible to move the order lines to the far right side.
[2016-11-11 01:19:10]
If Sierra thinks this could be done and add value to the platform, I think it could make the DOM more flexible and convenient.
Regards
Date Time Of Last Edit: 2016-11-11 01:24:47
