Date/Time: Sat, 11 Jan 2025 07:06:36 +0000
Missing miniNikkei data from 10 November: 9am to 10:15am
View Count: 759
[2016-11-10 20:50:52]
User13668 - Posts: 294
See attached chart.
Times are local Tokyo (USA ET is 14 hours behind).
The day session for 10th November [corrected from October] starts 8.45am Tokyo time with actual market trading from 9:00am. Data is only appearing from 10:15am.
Have checked directly via web browser with my CQG credentials at CQG Mobile and the chart on that site is showing data correctly ie populated from 9am through 10:15.
Have tried Edit > Delete All Data and Download (for current front month) and that had no effect.
Date Time Of Last Edit: 2016-11-10 21:42:03
imageF.US.MJNKZ16 [CB] 15 Min #1 2016-11-10 15_40_42.072.png / V - Attached On 2016-11-10 20:50:20 UTC - Size: 51.94 KB - 224 views
[2016-11-10 21:35:53]
NumbersBars - Posts: 141
@User13668
Wasn't 10 Oct exchange holiday in Japan? Health & sports day.
Why is there data at CQG mobile for nikkeimini?
[edit]
Just read your title of the thread, you mentioned 10 Nov. So not sure which day are you referring to.
I have no problem with 10 Nov data though.
Date Time Of Last Edit: 2016-11-10 21:39:53
[2016-11-10 21:46:01]
Re post #2
Thanks, corrected paragraph to say November.
Not sure what you mean about CQG Mobile/Browser? Why would there not be data there? You can trade any instrument you are subscribed to directly on the CQG Mobile/Browser platform. Great for disaster recovery - if your PC craps out just login to CQG on your phone and manage your positions.
Have you specifically got 10 November data for 9am to 10:15am Tokyo time?
[2016-11-10 21:52:56]
Ignore the CQG mobile i mentioned. I thought you can see data for 10 Oct on CQG mobile.
Here is the 1-min chart I have for 10 Nov 845am onwards. Tokyo (+9 JST)
imagenikkei10Nov.png / V - Attached On 2016-11-10 21:52:14 UTC - Size: 20.3 KB - 234 views
[2016-11-10 22:01:44]
Disregard the prior response. The session times were not set correctly. We are still looking into this.
[2016-11-10 22:07:00]
There should no longer be any missing data for this symbol at the mentioned time range. Follow through the instructions here:
Date Time Of Last Edit: 2016-11-10 22:07:32
[2016-11-11 00:12:34]
Re post #7 - followed all the steps, but that has not fixed the missing data.
It has now gone past 9:00am on the 11th in Tokyo and data for the 11th is populating correctly (at least that means Symbol and session times are not the issue - which I didn't think they were given data has populated correctly every other day).
[2016-11-11 01:19:04]
You must not have followed through the steps. The data absolutely is there. Follow through the instructions again:
Including updating the Symbol Settings.
Here is an image of the chart:
http://www.sierrachart.com/image.php?Image=1478827086414.png
Date Time Of Last Edit: 2016-11-11 01:20:09
