Date/Time: Sat, 11 Jan 2025 06:49:04 +0000
Transact datafeed quality
View Count: 1213
[2016-11-10 20:29:11]
Johnny - Posts: 99
Hello, I have registered for a transact demo and I have noticed that there's less volume displayed compared to the Sierrachart and OEC datafeeds which results in different volume profiles. Are you aware of this and do you know why there would be such big differences in volume?
[2016-11-10 21:42:49]
We would not expect there to be much difference and the difference is because TransAct does not count implied trades.
If you re-download the data following these instructions do you notice a difference after:
https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2
Date Time Of Last Edit: 2016-11-10 21:43:34
[2016-11-11 15:00:37]
Johnny - Posts: 99
I re-downloaded data and it makes no difference at all. I guess you're right about implied trades but they should include these like you do. The absence of these volumes makes the datafeed less accurate. I also face some other issues. When I load a Nasdaq chart (Transact symbol NQZ6) I get the error symbol is unknown and I don't get real-time quotes only historical. Also, after installing v1481 the message log window is black and I can't see any of the messages.
Date Time Of Last Edit: 2016-11-11 15:01:43
[2016-11-11 17:38:03]
You need to contact your broker about getting NQ real-time futures data.
Refer to the instructions here to change the colors used in the Message Log:
Message Log: Color Settings
