Date/Time: Sat, 11 Jan 2025 10:02:51 +0000
Windows in different screens
View Count: 892
[2016-11-10 20:01:14] |
User252419 - Posts: 235 |
Hello, Is it possible to have different chartbooks in different screens? Thank you, |
[2016-11-10 22:36:16] |
Only when using another instance of Sierra Chart: Data and Trading Communications (DTC) Protocol Server: Using DTC Server for Data and Trading in Another Sierra Chart Instance Each instance of Sierra Chart can display one Chartbook at a time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-10 22:36:52
[2016-11-13 06:10:06] |
User948528 - Posts: 108 |
You can also do it if they are detached windows and set to always visible.
[2016-11-13 08:58:47] |
Yes, to post #3.
[2016-11-21 12:39:53] |
How can I set to always visible and also have detached windows? thank you |
[2016-11-21 17:43:12] |
Follow the instructions here to detach a chart: http://www.sierrachart.com/index.php?page=doc/DetachingandAttachingChartWindows.html Use this command to make a chart window always visible: http://www.sierrachart.com/index.php?page=doc/WindowMenu.html#WindowAlwaysVisible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
