Date/Time: Sat, 11 Jan 2025 06:57:32 +0000
Issue with latest release
View Count: 756
[2016-11-10 15:53:08] |
User240686 - Posts: 86 |
This latest update has upset the volume profile on charts. In particular the composite now appears in a totally different part of the screen and sits directly behind price bars. When you try and move the bars to the left it also brings the profile with it. Very frustrating and i hope we can roll back |
[2016-11-10 17:51:21] |
You need to set this Volume by Price study Input to yes: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight (Align to Far Right) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-11 13:30:15] |
of course i have done that...nothing has changed in my set up other than updating you can see in the attached file the profile is wrongly placed |
Capture.PNG / V - Attached On 2016-11-11 13:29:48 UTC - Size: 69.57 KB - 239 views |
[2016-11-11 16:35:55] |
You could not have set that particular Input to Yes. That is clear from the screenshot you provided. You need to set this Volume by Price study Input to yes: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight (Align to Far Right) Or if you update to the latest Prerelease it will automatically be set to yes. Here are instructions to update to the Prerelease: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-11 16:36:58
