Date/Time: Sat, 11 Jan 2025 06:49:14 +0000
Upgrade from 1481 to 1483 "There is no new version available."
View Count: 654
[2016-11-10 12:09:04] |
DabbaDo - Posts: 148 |
I am running 1481 (which was a PreRelease). When I try do Help + Download Current Version I get this message -- "There is no new version available." -- and no upgrade. But 1483 has been available for almost 2 days, per https://www.sierrachart.com/index.php?page=doc/Whats_New.php So is there no way to switch from PreRelease back to Current Version? Or am I missing something here? Cheers, Dale |
[2016-11-10 17:47:14] |
Currently you are running the current version which is 1481. To get the prerelease 1483, you need to update to the "Prerelease" following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-10 17:47:37
