Date/Time: Sat, 11 Jan 2025 06:52:33 +0000
Option for choosing average color in Color Bar HH/LL study
View Count: 615
[2016-11-10 06:42:13] |
User857142 - Posts: 82 |
Hi I have a simple request of addition of couple of lines of code in an already in-built indicator Color Bar HH/LL https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s198 Here the neutral color is the average of up/down color which sometimes is not properly visible in different background. Since there is no option of choosing it, its pain to get the right color combination to set it right and thereby forces me to change the entire template+background. I would request you to give an option of choosing this average/reversal color in settings window and if possible in the next update. Thanks in advance! |
[2016-11-10 10:23:07] |
We will implement this.
