Date/Time: Sat, 11 Jan 2025 07:10:35 +0000
Child Client
View Count: 1371
[2016-11-10 02:19:08] |
sellis67 - Posts: 105 |
If i remove target and stop for an active trade and then enter a manual stop/target for the current trade, there seems to be a 'child client' bracket on either side of the trade. What is that and how do I remove it if I don't need it?
[2016-11-10 02:56:31] |
How are you doing this?: enter a manual stop/target for the current trade
And does this occur after doing the above?
[2016-11-10 03:07:26] |
1. Set a target and stop from the trade window. 2. Enter a trade 3. remove target and stop by clicking the 'X' 4. Enter a limit order buy/sell from the lower trade window 5. Once entered, the limit order is present as are two additional 'child-client' stops. |
[2016-11-10 04:59:11] |
What you need to do before doing step 4 is uncheck Use Attached Orders on the Trade Window: Attached Orders: Using Attached Orders and Attached Order Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
