Date/Time: Thu, 24 Sep 2026 22:17:43 +0000
[Programming Help] - Color Bars based on Heikin Ashi
View Count: 3460
| [2016-11-09 22:55:58] |
| User513959 - Posts: 16 |
Hi Ive attempted to try and accomplish this myself with "Color bars based on alert" but have not been successful. Is there a way to color regular candlestick bars based on the Heikin Ashi formula. Basically would go like this; HA bar is green + Candle closes green = green solid candlestick HA bar is green + Candle closes red = green hollow candlestick Inverse for red HA bars. Essentially Im looking to combine the trend follow characteristics of HA bars with real OHLC of regular candles. Thanks, Stefan |
| [2016-11-10 00:20:44] |
| Sawtooth - Posts: 4354 |
Try this: You'll need 4 instances of the Color Bar Based On Alert Condition study, one for each combination. You'll need to set the Chart >> Chart Settings >> Main Setting tab >> Graph Draw Type to Candlestick Bars Hollow. Use these formulas and Draw Styles, respectively, in each color bar study: HA green, candle green: =AND(ID1.SG1<ID1.SG4,O<C) Color Bar (use same green as in Graphics Settings) HA green, candle red: =AND(ID1.SG1<ID1.SG4,O>C) Color Bar Hollow (use same green as in Graphics Settings) HA red, candle red: =AND(ID1.SG1>ID1.SG4,O>C) Color Bar (use same red as in Graphics Settings) HA red, candle green: =AND(ID1.SG1>ID1.SG4,O<C) Color Bar Hollow (use same red as in Graphics Settings) Notes: -Above formulas assume the HA study is ID1. Edit as needed. -Above assumes the HA study is not set to Display as Main Price Graph |
| [2016-11-10 01:51:49] |
Amazing! Thank you!
