Date/Time: Sat, 11 Jan 2025 04:58:42 +0000
Can you show weekdays for daily charts?
View Count: 787
[2016-11-09 19:22:04] |
skelcap - Posts: 139 |
When I slide the crosshair on an intraday chart I see the date/times in format "Thu 2009-11-12" with the day of week. Is it possible to have the same thing on daily charts?
[2016-11-09 22:37:23] |
Yes this is possible and has already been implemented. You just need to update to the current version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-09 22:46:44] |
Thanks. Is there a way to automatically be updated to the latest version, or at least be notified when it is released?
[2016-11-09 23:21:35] |
Periodically we do put out update notices. We will do that.
