Date/Time: Fri, 03 May 2024 10:45:45 +0000
How to make the "Trade Triangle" bigger
View Count: 940
[2016-11-09 11:42:20] |
Autotrade8 - Posts: 26 |
Hi, For a very long time I am searching to make this small triangle bigger when a trade position is opened. It would be great because it's a little easier to find where the position was opened. I don't know how and maybe it's impossible but all the manuals are so overwhelming. I can't find a solution. Maybe you can help me please. For the record, I want only this triangle bigger, not something else. Sometimes I don't see the trees in the forest. Thanks! |
Triangle.png / V - Attached On 2016-11-09 11:40:55 UTC - Size: 1.7 KB - 274 views |
[2016-11-09 17:53:43] |
This is the Order Fills >> Fill Marker Size setting: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ChartTradeSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-31 04:13:42] |
User234172 - Posts: 44 |
Any chance to have these triangle markers smaller on Footprint charts. They are very large. Approx same size as the Large setting appears on a standard bar chart. Thank you.
