Date/Time: Sat, 11 Jan 2025 07:00:32 +0000
Add previously saved studies in DOM
View Count: 1135
[2016-11-08 20:35:05] |
User252419 - Posts: 235 |
Hello, I saved a study for DOM , but I don't know how to apply it in DOM again. If I click to Analysis and select the study for the DOM , it gets plotted in my charts and not in my DOM. Thank you |
[2016-11-08 21:31:32] |
There is not a way to apply Study Collections to a Trade DOM.
[2016-11-09 08:58:50] |
User34947 - Posts: 42 |
Attach Trade DOM window through Ctrl-Alt-D, select the study collection clicking Analysis, and then detach Trade DOM window using again Ctrl-Alt-D
[2016-11-10 09:28:13] |
Thank you, it works :)
