Date/Time: Sat, 11 Jan 2025 05:03:08 +0000
Switch Timeframes
View Count: 641
[2016-11-08 19:59:26] |
User39772 - Posts: 311 |
Hello, is it possible to switch the "Number of Trades per Bar" within a chart "on the fly", e.g. by a simple button, so that it is not necessary to enter "Chart Settings" every time I need to switch. |
[2016-11-08 21:32:15] |
Refer to this page: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-09 10:05:25
[2016-11-09 09:18:43] |
Hello, unfortunately I did not find the answer to my question here. I do not want to switch a symbol ! The symbol stays the same. I want to switch the "Number of Trades per Bar" that represent that symbol without using the "Chart Settings" dialog, e.g. by using customer specific buttons instead. |
[2016-11-09 10:04:54] |
We apologize for this. We provided you the wrong documentation link. This is what we intended to provide: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
