Date/Time: Sat, 11 Jan 2025 04:49:47 +0000
Remote Chart Data File
View Count: 815
[2016-11-08 19:55:19]
User781817 - Posts: 7
I would like to ask you regarding the function Remote Chart Data File. I have two copies of Sierra Chart on my computer. One copy is for downloading data from iQFeed and the second copy is connected to Interactive brokers. I tried to connect these two copies via Remote Chart Data File but the function does not appear under the File button. Does it still exist? Or there is some different feature for that? Please, could you help me with this issue? I already checked FAQ but I didn´t find the answer.
Thank you very much in advance,
Gabriela
Date Time Of Last Edit: 2016-11-08 21:24:19
[2016-11-08 21:24:07]
The most reliable way to accomplish this is to use the Sierra Chart Exchange Data Feed which directly integrates with trading services:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
You will save a lot of money and it is a much better data feed for various reasons.
However, to do what you want is documented here:
https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance
Date Time Of Last Edit: 2016-11-08 21:28:55
[2016-11-09 11:45:50]
Thank you for quick response. So you recommend me to use realtime data from Sierra Chart? I need very good tick data for my trading. You think this is sufficient? Can I quit iQfeed and use this instead? Thank you, Gabriela
[2016-11-09 17:55:10]
Definitely use the Sierra Chart Exchange Data Feed. It will meet your requirements. There is no need to use IQ Feed.
Here are the instructions:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
[2016-11-09 19:33:56]
Thank you for your help. I already change it.
Best regards,
Gabriela
