Date/Time: Sat, 11 Jan 2025 04:35:54 +0000
Custom text ACSIL
View Count: 991
[2016-11-08 15:54:55] |
User96015 - Posts: 55 |
Dear sir, I have to build a custom footprint as Numbers Bars indicator on sierra chart. My problem is that I understand that there isn' t the possibility to plot a variable text for each bar trough a text style subgraph, but only a constant text. Is it true? How can I do what I need? Thx. Bye. |
[2016-11-08 16:06:53] |
You can use the Text drawing tool from ACSIL: Using Drawing Tools From an Advanced Custom Study You can also use all 60 of the available Subgraphs and use different Text for each: ACSIL Interface Members - sc.Subgraph Array Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
