Date/Time: Sat, 11 Jan 2025 04:42:44 +0000
[Programming Help] - Trouble evaluating MACD values at previous closes
View Count: 703
[2016-11-08 15:47:19]
AcquaLife - Posts: 33
The title says it all. I want to evaluate MACD difference value at prior 15min bar closes. I want to save those into variables such as MACDDIFF1 MACDDIFF2 MACDDIFF3. I have been working with this code block provided by SC:
sc.MACD(sc.BaseData[SC_LAST], sc.Subgraph[0], 5, 10, 10, MOVAVGTYPE_SIMPLE);
//Access the individual lines
float MACD = sc.Subgraph[0][sc.Index]; //Access the study value at the current index
float MACDMovingAverage = sc.Subgraph[0].Arrays[2][sc.Index];
float MACDDifference = sc.Subgraph[0].Arrays[3][sc.Index];
//Copy to Visible Subgraphs
sc.Subgraph[1][sc.Index] = MACDMovingAverage;
sc.Subgraph[2][sc.Index] = MACDDifference;
So, what I have tried to do to evaluate the previous values of the MACD difference at previous 15min closes is
float MACDDifference1 = sc.Subgraph[0].Arrays[3][sc.Index-1];
float MACDDifference2 = sc.Subgraph[0].Arrays[3][sc.Index-2];
The sc.Index-1, sc.Index-2, ect. does not seem to work. I have tried using SC_LAST or sc.Close and someother things.
Please illuminate some light on what I am doing wrong.
Thank you so much.
On another note, I have to say thanks to SC for providing all of this functionality at such a low cost... wow, I have searched for a long time to find something like this, and got really lucky to stumble across SC!
[2016-11-08 19:53:44]
Hello, can someone at least please confirm that from the above code float MACDDifference1 = sc.Subgraph[0].Arrays[3][sc.Index-1] would have the value of the MACD difference at the close of the last bar that has closed?
[2016-11-08 21:33:23]
This is generally correct. Understand that sc.Index during a full recalculation starts off at zero and goes up to the sc.ArraySize -1.
Refer to:
Working with ACSIL Arrays and Understanding Looping
