Date/Time: Sat, 11 Jan 2025 04:58:59 +0000
Price not always highlighted on vertical scale
View Count: 736
[2016-11-08 10:28:27] |
User60518 - Posts: 106 |
Hi - on some charts in my chartbooks the current price isn't highlighted (white rectangle). I'm using 1483. Cheers |
[2016-11-08 15:15:34] |
Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-08 15:40:06] |
I hope this is correct - please see current price not highlighed - I can provide chartbook if need be. Cheers http://www.sierrachart.com/image.php?Image=1478619542259.png |
[2016-11-08 15:53:33] |
We will need to get the Chartbook, but provide only a single chart. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-09 15:39:10] |
here you go - please see attached
Chartbook1.cht - Attached On 2016-11-09 15:38:55 UTC - Size: 46.64 KB - 315 views |
[2016-11-09 18:09:58] |
OK we see what you have done. When using the Heikin-Ashi study you need to enable this option to make it the main price graph: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DisplayAsMainPriceGraph Do not set the Chart >>Graph Draw Type for the chart to Blank. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
