Date/Time: Sat, 11 Jan 2025 04:39:36 +0000
Market Depth Historical Graph features Request
View Count: 1177
[2016-11-08 04:04:52] |
User15952 - Posts: 132 |
I am nor sure where this should go; is there a specific thread to request additional features and improvements? if not, here goes; Would it be possible to have a start and end time for the data capture. Thanks |
[2016-11-08 04:12:59] |
This is extremely unlikely to be added.
[2016-11-08 04:14:26] |
This is exactly the type of request where the post here is highly applicable: Notice: Suggestions (Currently not accepting) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-08 14:43:58] |
conr - Posts: 204 |
It is an IMPORTANT feature otherwise you're just adding the previous day's info which provides a false read for current timeframe as well as too much noise above and below untouched prices for current timeframe. Also, is it possible to have the data go 5 or 10 deep like on a DOM? Thank you. |
[2016-11-08 15:23:00] |
What you are asking for is completely different. You are not asking about a time range, but it sounds like you are asking about excluding prior days when drawing the Market Depth Historical Graph. Also, is it possible to have the data go 5 or 10 deep like on a DOM? Are you referring to the Market Death Historical Graph? This already displays all of the market depth levels which can be 10 or more levels. We do not understand this request.
[2016-11-08 15:52:22] |
conr - Posts: 204 |
I do not want yest. info in today's. Are you referring to the Market Death Historical Graph? This already displays all of the market depth levels which can be 10 or more levels. We do not understand this request.
I should have been more clear. Sorry. While I realize this is a historical graph is it possible to make it live? Example. Currently ES is at high of day at 2125. Is it possible to graph the asks above as they are being added and removed just like a DOM? |
[2016-11-08 15:55:14] |
Market Depth Historical Graph does update with real-time data. Currently ES is at high of day at 2125. Is it possible to graph the asks above as they are being added and removed just like a DOM? This is already the case:https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-08 15:55:43
[2016-11-08 17:15:20] |
conr - Posts: 204 |
See the red circle above price. No asks being graphed until hit by price. Would like to see continuous updating above and below price just like a DOM.
DOM Gragh.PNG / V - Attached On 2016-11-08 17:13:09 UTC - Size: 25.82 KB - 272 views |
[2016-11-08 17:21:53] |
Post an image of the chart following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Do not use any other method. We will not accept another method. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-08 17:24:35] |
conr - Posts: 204 |
http://www.sierrachart.com/image.php?Image=1478625822987.png
[2016-11-08 17:40:22] |
Open a new chart, set the chart bars to 1 minute and then add the Market Depth Historical Graph study to the chart using default settings. Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-08 17:44:58] |
conr - Posts: 204 |
http://www.sierrachart.com/image.php?Image=1478627087525.png
[2016-11-08 17:46:44] |
OK we now recognize what is obvious. You need to activate the CME Group exchange that includes market depth data: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures You can activate this right now and then Sierra Chart will begin to receive the market depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-08 17:50:34
[2016-11-08 20:05:13] |
conr - Posts: 204 |
yes that did it. Sorry about that, I forgot there was a CME market depth activation required. One other question, now that it is working okay, it appears behind vol by price study. Is there a way to put on top instead of having to use the transparency setting on vol by price?
[2016-11-08 21:30:37] |
Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
