Date/Time: Sat, 11 Jan 2025 05:04:46 +0000
Move chart up and down without changing the scale
View Count: 1255
[2016-11-07 15:24:11] |
User252419 - Posts: 235 |
Hello, I can not move the chart up and down without changing the scale. Thank you, |
[2016-11-07 19:40:47] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-07 19:52:14] |
I don't find where it explains how to scroll up and down without changing the scale.
[2016-11-07 19:55:06] |
Refer to: http://www.sierrachart.com/index.php?page=doc/Scaling.html#InteractiveScalingMoveUpDown Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
