Date/Time: Sat, 11 Jan 2025 05:01:52 +0000
How to display time elapsed since last trade
View Count: 805
[2016-11-07 14:44:28] |
ticinotrader - Posts: 397 |
I would like to numerically display on the chart the time (in seconds) elapsed since the last trade (tick) happened. It should show something like a counter (clock) since the last tick traded. When there is a new tick, the counter would reset and start the counting again from zero. This way I can measure the frequency of trades. Is there any way to do this in Sierra? |
[2016-11-07 19:41:51] |
This is not supported but you could create a custom study to do this: http://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage Might be helpful to look at the Countdown Timer study for useful code: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-07 19:42:55
