Date/Time: Tue, 04 Nov 2025 18:08:34 +0000
Vertical Grid lines on different periods
View Count: 3893
[2013-04-01 15:50:18]
umair1 - Posts: 86
I have a tick chart and want to have vertical gridlines spaced 10 bars apart, but I also want to have vertical gridlines at each hour. Is it possible to do this? If not, can this feature be added? It would also be nice if you could change the color of the vertical gridlines for each period.
[2013-04-01 16:01:44]
Sierra Chart - Max - Posts: 5880
You will have to use the Vertical Grid feature for the line every 10 bars:
http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#Vgrid
As for the Lines every 1 hour, you will have to use the Time Line study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s181
Sierra Chart Support
[2013-04-03 03:57:35]
Another way to do this rather than using the Time Line study, which would require many instances of it, is by using the Color Background Based On Alert Condition study. Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s252
You will just need to specify a formula that gives you a line every hour.
Date Time Of Last Edit: 2013-04-03 03:57:52
