Date/Time: Sat, 11 Jan 2025 04:40:41 +0000
CQG FIX trading connection
View Count: 919
[2016-11-07 02:21:23] |
toews&kane - Posts: 209 |
My computer died, and backup wasn't working, I am setting up everything all over again. CQG fix trading I cannot get it to connect with my previous settings. Can I get some help for this? |
[2016-11-07 02:32:50] |
Reading Internal Order ID file. | 2016-11-07 00:27:22 Reading Trade Orders file. | 2016-11-07 00:27:22 Reading Trade Positions file. | 2016-11-07 00:27:22 Software version: 1457 | 2016-11-07 00:27:22 Uses New Spreadsheets | 2016-11-07 00:27:22 Usage end date: 2016-12-05 | 2016-11-07 00:27:22 Enabled for: Advanced Features. | 2016-11-07 00:27:22 Enabled for: Advanced Features 2. | 2016-11-07 00:27:22 Enabled for: Sierra Chart Historical Data Service. | 2016-11-07 00:27:22 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-11-07 00:27:22 Current selected Data/Trading service: SC Forex Data (FXCM) | 2016-11-07 00:27:22 Chart Update Interval: 900 | 2016-11-07 00:27:22 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-11-07 00:27:22 2016-11-06 21:27:30 Local computer time | 2016-11-07 00:27:22 2016-11-07 05:27:30 Local computer time in UTC | 2016-11-07 00:27:22 2016-11-07 00:27:30 Local computer time in SC Time Zone | 2016-11-07 00:27:22 2016-11-07 02:27:26 Server time in UTC | 2016-11-07 00:27:22 Local computer UTC time and Server UTC time difference: 10799 seconds. | 2016-11-07 00:27:22 Notice: Your computer's clock is off by 10799 seconds. For help with this, press the 'Send for Analysis' button. | 2016-11-07 00:27:22 Program path: E:\SierraChart\ | 2016-11-07 00:27:22 Data Files path: E:\SierraChart\Data\ | 2016-11-07 00:27:22 OS Version Number: 6.2 | 2016-11-07 00:27:22 Locale Setting: C | 2016-11-07 00:27:22 Checking for new symbol settings for fxcm | 2016-11-07 00:27:22 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-07 00:27:22 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-11-07 00:27:22 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-11-07 00:27:22 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-11-07 00:27:31 Symbol settings are up-to-date for fxcm | 2016-11-07 00:27:31 SC Forex Data (FXCM) | Connected to data server. | 2016-11-07 00:27:35 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-11-07 00:27:36 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-11-07 00:27:36 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-11-07 00:27:36 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-11-07 00:27:36 File >> Disconnect selected. | 2016-11-07 00:28:05 SC Forex Data (FXCM) | Disconnected. | 2016-11-07 00:28:05 SC Forex Data (FXCM) | Disconnected. | 2016-11-07 00:31:52 SC Forex Data (FXCM) | Disconnected. | 2016-11-07 00:31:52 Checking for new symbol settings for cqg | 2016-11-07 00:31:52 Current selected Data/Trading service: CQG FIX Trading | 2016-11-07 00:31:52 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-07 00:31:52 HTTPS connection to www.sierrachart.com:443 (6) | Connected. | 2016-11-07 00:31:53 HTTPS connection to www.sierrachart.com:443 (6) | Starting TLS 1.2 connection. | 2016-11-07 00:31:53 HTTPS connection to www.sierrachart.com:443 (6) | SSL connection established. | 2016-11-07 00:31:53 Requesting symbol settings for cqg. Overwrite = on. | 2016-11-07 00:31:53 Symbol settings received. | 2016-11-07 00:31:54 Processed received symbol settings | 2016-11-07 00:31:54 HTTPS connection to www.sierrachart.com:443 (6) | SSL connection closed by remote side. | 2016-11-07 00:31:59 HTTPS connection to www.sierrachart.com:443 (6) | Connection gracefully closed by remote side. | 2016-11-07 00:31:59 HTTPS connection to www.sierrachart.com:443 (6) | SSL object has been freed. SSL state is now disconnected. | 2016-11-07 00:31:59 HTTPS connection to www.sierrachart.com:443 (6) | Shutdown and closed. | 2016-11-07 00:31:59 |
[2016-11-07 04:22:44] |
Follow through the step-by-step instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
