Date/Time: Sat, 11 Jan 2025 04:40:24 +0000
1481 ?
View Count: 579
[2016-11-07 01:24:15] |
zippyzip - Posts: 293 |
File attached.
Date Time Of Last Edit: 2016-11-07 01:41:42
[2016-11-07 01:40:11] |
and also is it possible to have some kind of way to save dom separate from rest as i use a different kind of dom for ES then cl , but if i change it it changes the other one -
[2016-11-07 01:58:57] |
What is the question you have about version 1481? What specific settings are you referring to in the case of the Trade DOM that you want to have different? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-07 02:10:49] |
for instance if I have one ES chart and one CL chart i want to be able to use certain things on one chart dom for one market with out having them on the other market . but when i change one they both change . thanks |
[2016-11-07 03:30:58] |
If you are referring to the Chart/Trade DOM Columns, those are globally configured.
