Date/Time: Sat, 11 Jan 2025 04:51:34 +0000
Sierra fails to connect to OEC
View Count: 705
[2016-11-05 11:08:09] |
User504193 - Posts: 38 |
Hi, I've just started a new chart package and trying to connect my Gain Capital feed (OEC via s5). I've enabled the data for Sierra on my s5 portal, input all the required info, but it won't connect. Pls advise. Kind regards Tony Gwynne |
[2016-11-05 11:12:55] |
Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ServerAvailability Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
