Date/Time: Sat, 11 Jan 2025 04:57:36 +0000
Show orders on spreadsheet?
View Count: 618
[2016-11-05 01:58:54] |
User104854 - Posts: 456 |
Hi. I just simply want to know if I can have my orders show up on a spreadsheet study. All I'd like is when I'm in a position, whatever the values of my stop and target orders are will show up in cells on the spreadsheet. If I move my stop for instance then the cell value will change to the new value. Is this possible?
[2016-11-05 10:32:29] |
No. For this you will need to use ACSIL: Automated Trading From an Advanced Custom Study You could create a custom study which gets the orders and copies the order prices to a study Subgraph. This will then get outputted to the Spreadsheet in the columns where study data is outputted to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
