Date/Time: Sat, 11 Jan 2025 05:01:45 +0000
Volume At Price Treshold Alert V.2
View Count: 767
[2016-11-02 21:30:17] |
User60591 - Posts: 39 |
Hi, I would like to ask you if it's possible for you to make small upgrade on Volume At Price Treshold Alert V2 to also trigger alert for 0 value (use for it on bid volume, ask volume on numbers bars). if you set it to 0 now, it collors each bar since the condition is everything above 0. Thank you s Date Time Of Last Edit: 2016-11-02 21:33:39
[2016-11-02 22:09:51] |
This change will be out in the next release.
