Date/Time: Sat, 11 Jan 2025 04:39:46 +0000
Composite volume profile line
View Count: 854
[2016-11-02 20:03:46] |
User97684 - Posts: 136 |
Hi, please how to bring back the volume profile outline to the far right edge of the screen ? Since I updated Sierra yesterday, all my composite volume profile lines have moved to the inner right. thanks |
composite_profile_outline_to_the_far_right.png / V - Attached On 2016-11-02 20:02:58 UTC - Size: 517.16 KB - 250 views composite_line_not_at_end_of_screen.png / V - Attached On 2016-11-02 20:03:21 UTC - Size: 150.26 KB - 248 views |
[2016-11-02 20:54:41] |
You need to set this Volume by Price study Input: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight To Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
