Date/Time: Sat, 11 Jan 2025 04:54:51 +0000
Italy Webank
View Count: 1123
[2016-11-02 17:34:08]
User826284 - Posts: 1
Hello, I would like to know if your software would be compatible with webank.
They use this software to connect a third party software https://www.webank.it/wscmn/doc/ret/Manuale_T3_open.pdf the problem is that the manual is in italian and probably you can't understand it
Let me know if can you do some research about?
[2016-11-02 18:24:39]
If Webbank were to support the DTC Protocol:
http://dtcprotocol.org/
Then it will be compatible with Sierra Chart.
