Date/Time: Sat, 11 Jan 2025 03:56:37 +0000
DST
View Count: 682
[2016-11-01 14:28:13] |
ElmStreetTrader - Posts: 48 |
Hi there Could you please add a South African city to your time-zone menu as we don't have DST here. Thanks |
[2016-11-01 17:24:31] |
Yes. We will set this up. We will list it either as Johannesburg or Cape Town. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-01 17:25:40] |
For the time being, set up custom time zone settings. Refer to: http://www.sierrachart.com/index.php?page=doc/TimeZone.html#CustomTimeZones Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-01 17:25:57
