Date/Time: Sat, 11 Jan 2025 03:41:06 +0000
gain capital doesn't update
View Count: 1128
[2016-11-01 13:56:35]
natanibz - Posts: 135
Hello, the price doesn't update in real time with gain capital (OEC).
Date Time Of Last Edit: 2016-11-01 13:58:01
[2016-11-01 13:57:58]
dd45 - Posts: 41
same
[2016-11-01 14:07:23]
RadioDC - Posts: 29
I updated to version 1478 and have the same issue. No data feed. If I disconnect and reconnect the bars update, but still no live data.
[2016-11-01 14:21:03]
RadioDC - Posts: 29
The problem is with Gain Capital
[2016-11-01 14:21:34]
now the price updates
[2016-11-01 14:53:07]
Diomedes - Posts: 27
Same problem here, the problem was with Gain and seems to be working now, however I am missing 17min worth of data and trying to delete and download did not solve it.
Had this problem once before and was recommended to do this by Sierra Support:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart
Worked like a charm back then, not today. Any help please?
[2016-11-01 15:19:16]
patrick - Posts: 30
Sorry to add.
I used to use GAIN, and it has more frequent same old problems compared other feeds.
You might be better off with CGQ or Rithmic.
Also using GAIN, there is a slower and washing effect on changes in the DOM.
And I know some brokers push their clients to use GAIN.. which I do not understand
Sorry, just my ranting after seeing this post.
[2016-11-01 16:15:30]
At this time there is no missing historical Intraday data. Follow the instructions here to download the missing data:
[2016-11-01 16:47:54]
Sorry guys but its not working. Tried it multiple times, Updating the symbol settings, disconnecting the data feed and reconnecting it, deleting and downloading the data and I still have the 17min hole in all my charts and symbols. What am I doing wrong here?
[2016-11-01 17:20:27]
For what symbol?
[2016-11-01 17:28:02]
For all futures data I am looking at. CL, YM, ES, NQ, EZ, from about 15:12:15 to 15:29:30 Central European Time. There was some problem with OEC data feed in the early afternoon (morning US time), and I have this hole in the data from that period once it started to run properly.
[2016-11-01 17:41:28]
We apologize for this. When we checked earlier, we did not notice the missing data because we were looking at a 5 minute per bar chart, and it was not actually apparent to us but we do see it now.
The missing data has been filled in.
Follow the instructions here:
[2016-11-01 17:46:31]
User34424 - Posts: 21
My Market Depth Historical Graph is not working
It's beacuse the GAIN problem?
[2016-11-01 18:01:39]
The first step is to follow through the instructions here:
http://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StepByStepInstructions
[2016-11-01 18:04:03]
since it's not my first use (and it worked yesterday) - these settings are already set
[2016-11-01 18:09:37]
Is market depth data being received? You can tell through File >> Open Market Depth Window.
[2016-11-01 18:29:07]
I see only 1 bid and 1 ask
I don't think it's normal
[2016-11-01 18:44:30]
Yes that is the problem. You need to contact your broker and have them authorize your account to receive the full market depth data from the CME.
