Date/Time: Sat, 11 Jan 2025 03:38:08 +0000
[Programming Help] - Spreadsheet Trading CROSSOVER/ABOVE/BELOW Question
View Count: 1622
[2016-11-01 02:50:16]
doctor10 - Posts: 78
Basic question about CROSSOVER/ABOVE/BELOW.
Is there a way to set a condition where if the lines touch(triggering an entrance or an exit)but do not end up crossing the system will go flat or reenter the previously held position?
- D
[2016-11-01 04:23:50]
No. You really need to create your own custom formula to accomplish this rather than using the CROSS* functions.
Furthermore, it is very unlikely when comparing floating point values to ever have a "touch/equal" condition.
[2016-11-01 10:41:07]
well, I have it all the time. Hence the question.
I take it you can't think of a way to accomplish this?
Thanks for the help!
[2016-11-01 11:06:17]
Your blase response pissed me off so bad i figured it out! thanks!
[2016-11-01 16:58:11]
You need to write your own custom formula. Here is the source code for the crossover function which will help:
  int CrossOver(SCFloatArrayRef First, SCFloatArrayRef Second, int Index)
    float X1 = First[Index-1];
    float X2 = First[Index];
    float Y1 = Second[Index-1];
    float Y2 = Second[Index];
    if (X2 != Y2) // The following is not useful if X2 and Y2 are equal
      // Find non-equal values for prior values
      int PriorIndex = Index - 1;
      while (X1 == Y1 && PriorIndex > 0 && PriorIndex > Index - 100)
        --PriorIndex;
        X1 = First[PriorIndex];
        Y1 = Second[PriorIndex];
    if (X1 > Y1 && X2 < Y2)
      return CROSS_FROM_TOP;
    else if (X1 < Y1 && X2 > Y2)
      return CROSS_FROM_BOTTOM;
    else
      return NO_CROSS;
